Pneumadyne introduces the new ‚“22‚†Series Solenoid and Air Pilot Operated Valves in 3-Way and 4-Way configurations with 1/8 NPT (F) ports. These high flow valves provide a flow rate of 40 scfm at 125 psi and feature single or double air pilot and solenoid operators. 1 Watt, 15 mm solenoid valves consume less power and offer a variety of connector and voltage options. The 4-way valves also include a 3-Position version with either Closed or Exhaust centers.
Precision machining and the exclusive PneuTef‚â„¢ process ensure a long product life and enable the valves to be used with lubricated and non-lubricated air. A special seal material also accommodates low temperature applications. Two to 10-station manifolds are available for mounting convenience.
Filed Under: Pneumatic equipment + components, Valves
