Southco launches compact electronic slide bolt
By Mike Santora | July 10, 2019
Southco-EM-05-slide-boltSouthco, Inc., has expanded its line of electronic access control solutions with a compact electronic slide bolt that simplifies the upgrade from mechanical to electromechanical latching. The new EM-05 4 Series Slide Bolt integrates an electronic lock with latch bolt position sensing and door sensing, allowing for simple monitoring of door and latch status.
Southco’s EM-05 4 Series Electronic Slide Bolt features high energy efficiency, requiring no power draw to maintain its retracted or extended position. With its compact size, the lightweight 4 Series Electronic Slide Bolt can be easily installed in tight spaces and is adaptable to various mounting requirements. Simple to install and operate, the economical 4 Series uses a spring-loaded, gear motor-driven mechanism that provides a secure and reliable alternative to solenoid solutions in high-volume dispensing and storing applications.
General Manager Steve Spatig adds, “The new EM-05 4 Series Slide Bolt offers a simple, cost-effective upgrade to electromechanical access control that offers more energy efficiency and reliability than traditional solenoid solutions. With integrated latch bolt position sensing and door sensing, the 4 Series allows simple monitoring of door and latch status for added security.”
Southco
www.southco.com
Filed Under: Fastening + joining • locks • latches • pins, Springs
Tagged With: Southco
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
