Southco, a provider of engineered access hardware has extended its line of positioning technology with a compact display arm.
The new AV D32 mounting arm lets users adjust the display height of monitors and screens, delivering reliable positioning in a reduced form factor.
The AV D32 Dynamic Mounting Arm (C Series) is a horizontally mounted display positioning solution that allows for vertical adjustment of screens and monitors in applications too constrained for larger height-adjustable arms.
The AV C Series The C Series allows a monitor to be easily tilted and rotated, swivels at the base of the assembly and can be lowered 60 degrees from the fully extended position for optimal display viewing. It features a high-weight capability that supports heavy monitors (up to 28 pounds) and accommodates a wide range of display sizes.
With its streamlined design, the AV C Series provides enhanced aesthetic appeal with integrated wire management and minimal joints for easy cleaning. Southco’s complete line of AV Display Mounts solutions eliminate the need for constant maintenance and readjustment, enable effortless fingertip positioning and boast a tested, repeatable cycle life validated for 20k cycles of operation.
“Southco’s AV D32 Dynamic Mounting Arm (C Series) provides ergonomic height-adjustable positioning of monitors and touchscreens in applications where space is at a premium,” adds Global Product Manager Stewart Beck. Offering proven positioning technology in a compact package, the AV D32 C Series features an ergonomic design that is easy and intuitive to operate.”
