Southco’s hinges are designed to add functionality to doors and panels, offering high quality feel and performance that lasts over the lifetime of the application.
Southco has extended its successful line of externally mounted free-swinging hinges with three new options designed for heavy-duty applications.
The EH Free Swinging Hinge is now available in corrosion-resistant aluminum for outdoor use, a lightweight plastic version that provides optimum strength for indoor and outdoor applications, and a zinc version for indoor use.
The newest additions to Southco’s EH Free-Swinging Hinge series offer new solutions for a broad range of door dimensions and weights. Available in sizes up to 100mm, the EH Plastic Free-Swinging Hinge series provides a high-strength, economical solution for multiple interior and exterior application zones.
The EH-8C Aluminum Free-Swinging Hinge features corrosion resistance, with adjustability for large panels where mounting space is limited. Together with the EH-7A Zinc Free-Swinging Hinge, these hinges deliver high strength in a compact package, lowering overall equipment costs and reducing application weight.
“Southco’s new plastic, aluminum and zinc EH Free-Swinging Hinges extend our trusted line of surface mount hinges to address the requirements of heavy-duty applications,” said global product manager Stewart Beck. “The plastic hinge is compact and powerful, the aluminum hinge provides corrosion resistance, and the zinc hinge features adjustable mounting, offering solutions for demanding industries including HVAC, industrial equipment, and transportation.”
Benefits
- Wide range of materials and styles
- Long repeatable cycle life
- Simple mounting and installation
- Maintains consistent performance without maintenance or readjustment
Filed Under: Flanges • supports • mounts • brackets • hinges
