Southco, Inc., a global provider of engineered access solutions, has expanded its line of VISE ACTION Compression Latches with a new version that allows visual confirmation of latch open status.
Southco’s new E3 VISE ACTION Compression Latch with Visual Indicator features is designed for heavy use and is NEMA 4 and IP65 compliant.
Southco’s E3 VISE ACTION Compression Latch with Visual Indicator features red reflective indicator wings that can be easily viewed when the latch is open, allowing latch status to be monitored at all times.
This new offering expands the line of MAKE SAFETY VISIBLE BY SOUTHCO products, which provide visual indications for improving safety and monitoring access in a wide variety of applications.
The new compression latch displays latch open status that can be seen from a minimum of five meters, making it an ideal choice for rail, semiconductor, and industrial machinery enclosures where an unsecured door or panel could impact safety during operation.
By allowing operators to easily detect latch status, the latch improves efficiency, enhances safety, and reduces maintenance errors. It’s also NEMA 4 and IP65 compliant, making it a suitable choice for outdoor, high-vibration or corrosive environments.
“The E3 VISE ACTION Compression Latch with Visual Indicator provides visual feedback of whether a panel is fully closed, semi-closed or not secured at all,” said Southco commercial product manager, Jonathan Coulter. “Like Southco’s standard E3 line, the indicator version delivers robust, vibration-resistant fastening and is available in a variety of grip lengths, providing a simple upgrade for enhancing enclosure safety and security.”
You may also like:
Filed Under: Clamps • locks • latches
