Southco’s new electronic slide bolt provides door & latch status monitoring
By Michelle Froese | July 9, 2019
Southco, Inc. has expanded its line of electronic access control solutions with a compact electronic slide bolt that simplifies the upgrade from mechanical to electromechanical latching. The new EM-05 4 Series Slide Bolt integrates an electronic lock with latch bolt position sensing and door sensing.
“The new EM-05 4 Series Slide Bolt offers a simple, cost-effective upgrade to electromechanical access control that offers more energy efficiency and reliability than traditional solenoid solutions,” explains Southco GM, Steve Spatig. “With integrated latch bolt position sensing and door sensing, the 4 Series allows simple monitoring of door and latch status for added security.”
Southco’s EM-05 4 Series Electronic Slide Bolt features high-energy efficiency, requiring no power draw to maintain its retracted or extended position. With its compact size, the lightweight 4 Series Electronic Slide Bolt is easily installed in tight spaces and adaptable to various mounting requirements.
Simple to install and operate, the economical 4 Series uses a spring-loaded, gear motor-driven mechanism, which provides a secure and reliable alternative to solenoid solutions in high-volume dispensing and storing applications.
Southco, Inc.
www.southco.com
Filed Under: Clamps • locks • latches
Tagged With: Southco
