Southco, a provider in engineered access hardware, has introduced the latest product in its successful line of magnetic catches, with a new version that combines strength and style.
The M5 Magnetic Catch holds entry doors, hatches, cabinet doors, and lids open or closed, while preventing damage caused by swinging into adjacent surfaces.
Constructed of corrosion-resistant stainless steel, the M5 Magnetic Catch combines a highly polished finish with the holding power of rare earth magnets to provide a sturdy and attractive solution for keeping doors and panels open or closed.
Southco’s M5 Magnetic Catches:
- Offer a reliable alternative to door stays
- Are well-suited for high-vibration environments
- Can be configured to provide nominal holding powers from 50-118 N (11-26 lbs)
- Can accommodate multiple door sizes and weights with a significant tolerance for misalignment
With simple push-to-close and pull-to-open functionality and a stylish high-gloss, stainless steel appearance, M5 Magnetic Catches offer an attractive solution for cabinets and doors in a variety of applications.
“Styled to complement applications including RV, rail, bus and marine equipment, Southco’s M5 Magnetic Catches provide the strength necessary to keep doors and panels in place with a range of configurations for flexible mounting and alignment,” said Cindy Bart, global product manager with Southco. “With its highly polished, stainless steel construction, the M5 offers exceptional corrosion resistance for challenging environments.”
M5 Magnetic Catches are available in a range of swivel catch height options that can be mounted horizontally or vertically, and fixed catch options that mount flush to or directly on the surface to suit a wide range of door, panel, and window dimensions.
Swivel catches are easily adjusted to hold at any desired angle and include a rubber bumper surface to minimize noise from closing and vibration, while preventing scratching of the mating fixed catch.
You may also like:
Filed Under: Clamps • locks • latches
