Shafts “backlash” to connect in a simple and fast two or more components of a mechanical transmission far between. The size of the extension is customizable to obtain a specific DBSE with different types of locks on the trees. Lengths up to 3 meters without intermediate support.
Compact and rugged.
low inertia.
High torsional stiffness.
Wear-free for lasting reliability.
Flexibility of connection of the hubs on the shafts.
Stretch customizable for a specific DBSE.
Possibility of lengths up to 3 m without the use of intermediate supports.
Torsionally rigid spacer shaft coupling with flexible bellow element GSF/DBSE
Hubs and spacer made of fully turned aluminum.
Stainless steel bellow.
Maintenance free.
Low inertia.
High angular misalignment recovery.
1 or 2 piece clamp hub with or without keyway.
Customised spacer for specific DBSE with torsional rigidity.
Compatible with high temperatures.
ComInTec
www.comintec.com
Filed Under: Coupling Tips
