Special lubricant grease for small gears subject to high loads
By Leslie Langnau | November 26, 2018
Klϋber Lubrication introduces Klübersynth GE 14-151, a special grease for highly loaded small gears like those found in power tools.
This product consists of a finely balanced combination of ester and synthetic hydrocarbon base oils with an aluminum complex soap thickener. Klübersynth GE 14-151 has a wide service temperature range, good wear protection properties and a high scuffing load capacity. It also offers excellent protection against tribocorrosion.
Klübersynth GE 14-151 can be used to lubricate toothed wheels, bearings, joints and slideways. The optimized oil release behavior enables use in applications that are not sealed oil tight. With a high scuffing load capacity and good backflow behavior, the grease allows lubrication of gears with a high sliding ratio. Depending on temperature, load and sliding speed, Klübersynth GE 14-151 can even be used on steel/steel, steel/aluminum and aluminum/aluminum components. When used for lubricating trapezoidal and ball-and-screw spindles, it offers excellent wear protection and smooth running.
Klübersynth GE 14-151 can be used in gears operating at peripheral speeds of approximately 10 m/s with a quasi-complete fill of the gear housing. It can maintain speeds of 20 m/s over short-term or intermittent operation. Tooth flank lubrication allows a speed of 3 m/s.
Klüber Lubrication
www.klueber.com
Filed Under: MOTION CONTROL
Tagged With: kluberlubrication
