Klübersynth MR 96-31 is a dynamically light grease, using a polyalkylene glycol base oil and a unique mix of solid substances. The lubricant reduces vibration, dampens noise and enables smooth motion of many different plastic materials. It is also compatible with elastomers and plastics over a wide range of temperatures, -40° C to 120° C. It was developed to reduce friction in material pairs involving critical, non-polar polymers such as PP or PE, and elastomers such as EPDM. The lubricant is also compatible with POM (homo- and copolymers), PBT or PA 6.6. It can also be used in slideways and casings made of non-polar and amorphous polymers with a low degree of crystallization. Other applications include vehicle brakes, electric parking brakes and small gears.
Klüber Lubrication
www.klueber.com
