Speed-lock double snap connectors from Emerson enable faster connections
By Mary Gannon | May 22, 2018
Electricians can connect armored cable, metal clad cable or flexible metallic conduit to steel boxes twice as fast and at less cost than traditional connectors by using Emerson Appleton Speed-Lock double snap connectors.
Emerson Connectors SpeedLockSpeed-Lock connectors require no tools or a locknut, leading to overall job cost savings without compromising quality. The patented connectors install in seconds. Electricians simply snap the connector onto the cable, and then snap it into the knock-out. Besides being faster to install, SPEED-LOCK connectors feature a unique design that eliminates loose component parts for total reliability.
Speed-Lock connectors are available in several configurations including straight, straight for old work, duplex for installing two cables in a single KO, and 90 degree. The zinc connectors are reusable and designed to terminate 3/8 or 1/2 in. flexible conduit in 1/2 in. steel box KO’s or enclosures in dry locations. Adding to the connectors’ value are red insulated throats that create a smooth pulling surface to protect the wire insulation from damage.
Speed-Lock double snap connectors are cULus listed for use in NEC and CEC governed locations.
Emerson
www.emerson.com
Filed Under: Connectors (electrical) • crimp technologies
Tagged With: emerson, emersonconnectors
molex-versablade-300x300
Heilind Electronics now offering Molex VersaBlade Wire-to-Wire Connector System
bel-stewart-m12xcode-connector
Stewart Connector M12 X-Code PCB mount connectors
Heilind-electronics-product-image
Heilind Electronics now offering Molex PowerPlane BusBar Power Connectors
Harting Technology Group heads for a climate-neutral future with record investment
