Speeding up Data Storage by a Thousand Times with ‘Spin Current’
By Eindhoven University of Technology | July 10, 2014
A simplified representation of the new technology is shown. Two magnetic layers, each with a different magnetization, are separated by a neutral layer. A laser pulse strikes electrons in the upper layer. This causes them to move through the material, in the direction of the second layer. The spin of these electrons, in the direction of the magnetization of the upper layer, exerts a force on the spin of the electrons in the lower layer to make them rotate in the same direction. This makes the magnetization in the second layer change. (Eindhoven University of Technology)TU/e researchers show promising technology in Nature Communications
A hard drive stores bits in the form of tiny magnetic domains. The directions of the magnetic north and south poles of these domains, which are referred to as the magnetization, determine whether they are a 0 or a 1. Data is stored by changing the direction of the magnetization of the associated bits. At present this is done using a write head to create a local magnetic field, which makes a bit change direction.
Limit Reached
The stronger the local magnetic field, the faster the switch takes place. But this is subject to a limit which has now almost been reached. “The number of bits has been growing rapidly for many years, but the write speed has hardly increased. There’s a need for a new data storage technology,” says TU/e researcher Sjors Schellekens. He is the lead author of a publication in Nature Communications, in which together with colleagues he presents a new technology.
Magnetic Stream
The physicists, led by TU/e professor prof.dr. Bert Koopmans, use a special property of electrons, the spin – a kind of internal compass in the electron. Using ultra-fast laser pulses they generate a flow of electrons in a material which all have the same spin. The resulting ‘spin current’ changes the magnetic properties of the material (see the figure for an explanation of the technology).
A Thousand Times Faster
“The change in the magnetization is of the order of 100 femtoseconds, which is a factor 1,000 faster than what is possible with today’s technology”, says Schellekens. As well as that, the researchers were able to describe the physical processes that are involved in detail. “There was discussion among physicists about whether the generated spin current is actually able to cause the change in magnetization. We now definitely show that this is really the case,” says Schellekens.
Optical Computer Chips
In addition, the method is a step towards future optical computer chips, which TU/e is now working on. In December the university received a Dutch grant of almost 20 million euros to integrate photonics in computer systems. “Our technology allows optical data to be stored in the form of magnetic bits. That offers unprecedented opportunities if you want to use light as information carrier,” says Schellekens.
For more information, visit www.tue.nl/en.
Machine Learning for Sensors
