Sunnyvale, CA — IDEC introduces a new line of Surface Mount Indicators, the LH series of LED Spider Lights. These slim and stylish LEDs are perfect for mounting on the surface of equipment or panels, while maintaining excellent visibility from the front and the side.
LH1D spider lights can be used in various applications that do not have space behind the panel.These include robotic arms, product picking, door monitoring and other applications where you can use dual-color pre-wired LED spider lights rather than drilling two 22mm holes to mount two pilot lights.
Offered in seven bright colors (red, green, blue, amber, yellow, cool white, warm white), these 24V AC/DC Spider Lights maintain an impressive 50,000 hour lifespan while consuming low levels of energy. A red/green two-color alternate illumination is also available giving customers a 2-for-1 option. Legends, symbols or even company names can be printed on marking film for the flat type to personalize lights.
LH Series of lights are UL listed, CE marked and TUV rated. All Spider Lights are also IP67 rated for protection against exposure to water or oils. LH1D Spider Lights are available with 1m, 3m and 5m cables.
IDEC Corporation
www.idec.com/usa
Filed Under: Electronics • electrical, Lights • signal lamps • indicators
