SPIROL International Expands Disc Spring Product Line
By Patrick Curran | September 7, 2011
SPIROL International Corporation announces the expansion of their Disc Spring product line.
Disc Springs are conically-shaped, washer-type components designed to be axially loaded. They can be used individually or assembled into stacks to achieve the desired deflection characteristic required for the application. SPIROL Disc Springs’ performance characteristics are predictable and the minimum life cycle can be calculated. They also provide high levels of load / force within a very small space unlike other springs which require a significantly larger footprint to achieve the same load. Due to their predictability, high reliability and unparalleled fatigue life, Disc Springs are preferred over all other types of springs in critical applications such as safety valves, clutch and brake mechanisms for elevators and heavy equipment, and supports for industrial pipe systems.
The two major updates to the newly expanded product line are larger sizes per DIN 2093 Group 2 (now available up to 250mm in diameter), as well as a full range of stainless steel Discs. Details are provided in the updated Disc Spring design guide.
www.spirol.com
Filed Under: Fastening + joining • locks • latches • pins, Washers • spacers
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
