SPIROL launches eCommerce for Coiled Spring Pins
By Lisa Eitel | December 15, 2017
SPIROL now offers a new, secure, and easy-to-use eCommerce platform at Shop.SPIROL.com. While all of SPIROL’s engineered components will eventually be available for purchase through Shop.SPIROL.com, the first product available for online purchase is the Coiled Spring Pin.
As the inventor of the Coiled Spring Pin in 1948, SPIROL has set the industry standard for this unique engineered fastener. SPIROL offers the world’s largest standard offering of Coiled Spring Pins available in light, standard and heavy duties in diameters ranging from 0.8 mm (1/32 in.) to 20 mm (3/4 in.). Visitors to Shop.SPIROL.com can also request certifications, search by specification, select from several materials and finishes, as well as submit a request for custom sizes and specifications.
In addition to being able to purchase Coiled Spring Pins, design engineers can conveniently download 2D drawings and 3D models directly from Shop.SPIROL.com. Drawings and models will be available for each product line as they are offered.
SPIROL is initially launching their eCommerce program for Coiled Spring Pins available for purchase in the United States and will add their other product lines as well as implement eCommerce for their global offices in the upcoming months.
SPIROL INTERNATIONAL CORP. is a leading manufacturer of a diverse line of engineered components for fastening and joining, including Coiled Spring Pins, Slotted Spring Pins, Solid Pins, Disc Springs, Alignment Dowels and Bushings, Spacers, Compression Limiters, Threaded Inserts for Plastics, Precision Shims, Pin and Insert Installation equipment. SPIROL can be found on 4 continents within the following 12 countries: Brazil, Canada, China, Czech Republic, England, France, Germany, Mexico, Poland, South Korea, Spain, and the United States. Since 1948, SPIROL has been providing technical expertise in fastening, joining and assembly to the world’s leading manufacturers.
Filed Under: Fastening + joining • locks • latches • pins
Lisa Eitel
Lisa Eitel has worked in the motion industry since 2001. Her areas of focus include motors, drives, motion control, power transmission, linear motion, and sensing and feedback technologies. She has a B.S. in Mechanical Engineering and is an inductee of Tau Beta Pi engineering honor society; a member of the Society of Women Engineers; and a judge for the FIRST Robotics Buckeye Regionals. Besides her motioncontroltips.com contributions, she also leads the production of the quarterly motion issues of Design World.
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
