SPIROL Publishes New Corporate Brochure
By Laura Carrabine | October 14, 2011
SPIROL is a technical resource that provides high quality components that improve the quality of your assembly, extend the life of your products and reduce your manufacturing costs.
SPIROL possesses unparalleled Application Engineering knowledge and a vast product offering. Through partnering with companies in the design stage, they help design not only the engineered component and installation equipment used for fastening and joining, but they also supply the critical recommendations for the interface between their product and your assembly.
SPIROL brochure
SPIROL is the only manufacturer of engineered fasteners that offers a total integrated solution. Since the invention of the Coiled Spring Pin in 1948, SPIROL continues to introduce new products and improve existing ones — passing substantial savings on to you. Their diverse product line includes Coiled and Slotted Spring Pins, Solid Pins, Disc Springs, Alignment Dowels and Bushings, Spacers, Compression Limiters, Machined Nuts, Inserts for Plastics, Shims, and Installation Equipment. Most heat-treating and finishing processes are performed in-house to ensure consistent quality. You benefit from a choice of over 30,000 standard products, no tooling or development costs, less variability between production lots, and responsive delivery.
SPIROL
www.SPIROL.com
Filed Under: Assembly, Fastening + joining • locks • latches • pins
C2 lever latch offers auto-relock functionality and modern appearance
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
