SPIROL’s Next Generation Model DP Drilling and Pinning Machine
By Editor | October 3, 2013
SPIROL International is pleased to announce the release of the next generation Model DP Drilling and Pinning Machine. The Model DP is a self-contained vertical drilling and pinning machine that eliminates the requirement for manufacturers to maintain tight tolerances and precision drill individual components to ensure that the holes are to the correct size and properly aligned in a multi-component pinned assembly.
SPIROL's-Next-Generation-Model-DP-Drilling-and-Pinning-Machine
The Model DP consists of an automatic high-precision drilling unit, a SPIROL Model CR Pin Insertion Machine and a precision air-powered linear slide unit to move the assembly between the drill unit and installation station. Considering that the drilling and pinning operations are all completed with one machine, the Model DP eliminates the need for operators to handle the components multiple times through several processes. The machine is highly versatile and can be easily configured to accommodate a variety of applications.
Click here for the information data sheet on the new Model DP Drilling and Pinning Machine that provides the features and benefits of the machine, as well as a case study about how the Model DP helped a customer simplify the assembly process and double their previous production output with a payback of less than 12 months!
SPIROL
www.spirol.com
Filed Under: ALL INDUSTRIES, Machine tool industry + subtractive manufacturing, Fastening + joining • locks • latches • pins
Tagged With: SPIROL
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
