    • On the Floor
split frame machines with tooling modules that hold double edge blades
By Mike Santora | May 28, 2024
COHOG Split Frame Machine Performs Parting and Double Beveling
A line of split frame machines with tooling modules that hold double-edge blades that perform parting and double beveling for inline valve installation and replacement has been introduced by Esco Tool of Holliston, MA.
The Esco COHOG Split Frame Machine features a robust stationary ring machined from 7075 aluminum alloy that is hard coated and supports a custom steel forged, heat-treated, and nickel-plated rotating ring. Featuring a tooling module that holds double-edge blades, it is easy to set up using indexable tooling to perform parting and double beveling simultaneously.
Providing vibration-free operation, the Esco COHOG Split Frame Machine self-squares and can be precisely aligned and quickly attached without shims or guesswork and the rotating ring is supported by precision-tuned eccentric bearings. Motor options include pneumatic, electric, or hydraulic power and the double-edge blades reduce the cost of consumables.
ESCO Tool
esco.net
Filed Under: Bearing Tips
Tagged With: ESCOtool
  • Toyota goes all-in on humanoid robots
  • Mobile robotics moves to the textile industry
  • Finally, hard data on humanoid robot cost in the factory
    • On the Floor
