Split plummer block housings SNV:
are designed in accordance with a modular concept and are highly versatile in application
are suitable for different bearing types and sizes with bore diameters from 20 mm to 160 mm
can be combined with an extensive range of seals covering a wide range of requirements and temperatures
Housings for a wide range of applications
Split plummer block housings SNV and the associated bearings form bearing arrangement units that can be matched, through the appropriate selection of accessories, to a wide range of applications. Applications include agricultural machinery, the paper processing industry, mining, materials processing, the steel industry, and power stations.
Schaeffler
medias.schaeffler.us/en/split-plummer-block-housings-snv
Filed Under: Bearing Tips
