New Hyde Park, NY – New spring suspension mounts from Advanced Antivibration Components (AAC) are designed to isolate suspended products that weigh from 22 up to 705 lbs. A popular use for these vibration isolators involves their use in suspending piping in heating, ventilating and air conditioning (HVAC) applications.
There are 11 mounts identified as the V11Z71MKSH… Series constructed with a zinc-plated steel housing. The spring is made from hard drawn steel that is painted. The lower plate is made of neoprene. By having rubber on both ends of the coil spring, the unit can reduce vibrations for a wide range of frequencies. They are best suited for hanging from ceilings small machines such as fans, distribution pipes and ducts. At the AAC eStore you can check price and availability, place an online order, download 3-D models, or request a quote at anytime.
http://vibrationmounts.com/
Filed Under: AUTOMATION, Shocks + vibration control • gas springs
