With a new dampening system the SRU-plus rotary actuator from SCHUNK can rotate heavy loads just like its predecessor the SRU. The new unit is available in six different sizes. The user can choose between two dampening versions. The soft dampening version ensures shorter cycle times even with the same payloads; the hard dampening version enables the handling of a heavier payload with the same body size.
The completely revised rotary module series from SCHUNK has many options, including electric and fluid feed through, continuous adjustment of the end positions, as well as pneumatic or locked middle position versions. Furthermore, it is interchangable with its predecessor, which ensures a hassle free upgrade to the SRU-plus.
SCHUNK
www.schunk.com
Filed Under: Factory automation, Actuators, AUTOMATION, Motion control • motor controls
