Stackpole’s ASRM2 2-Watt Resistors
By Natasha Townsend | June 12, 2012
Stackpole’s addition of ASRM2 is a mini 2 W power rating in its ASR series of axial leaded anti-surge resistors.  It is the same size as the ASR1, has the same working voltage rating of 4 KV and overload voltage rating of 5 KV, yet rated for 2 W of continuous power.  The ASR series is designed to handle high voltage pulses of up to 10 KV depending on size and resistance value, for thousands of pulse events.  The ASR has a flameproof coating per UL94 V-0 and is RoHS compliant.
The ASRM2 is ideal as a surge resistor for many types of power supplies, CRT’s and other types of displays, small motor controls, security systems, industrial automation and controls, snubbers, power supply primary side discharge resistor, LED lighting.  This series is also well suited for high voltage applications including medical applications, plasma cutters, welding equipment, personal protection devices, power and phone distribution protection, and instrumentation.
Pricing for the ASR / ASRM varies with size and resistance value and ranges from $0.045 to $0.12 each in full reel quantities.
Stackpole Electronics, Inc.
www.seielect.com
Power Supply Tips
Filed Under: Power Electronic Tips
