    • On the Floor
Stafford Rigid Coupling Adapters
By Patrick Curran | June 30, 2009
Stafford Manufacturing Corp. introduces a new standard line of rigid shaft coupling adapters that mate dissimilar style shafts to simplify retrofit, maintenance, and repair applications.
Stafford Rigid Coupling Adapters provide an effective way to upgrade and retrofit machinery and conveyor drive components by permitting the user to change the configuration and size of the output shafts with minimal effort. Featuring clamp-type female ends that fit securely over an existing shaft, these coupling adapters incorporate female and male shaft ends that can be custom manufactured to specification or re-machined by the user.
Available in steel, stainless steel, and aluminum, Stafford Rigid Coupling Adapters are offered in sizes from 1/8” to 8” I.D. with shafts to 8” O.D. and lengths up to 4 ft. long, depending upon the bore size. The clamp-type female ends can be supplied with keyways and other I.D. modifications and the output shafts can be threaded, hex, and square configurations.
www.staffordmfg.com
Filed Under: Couplings, Motion control • motor controls
Tagged With: Stafford Manufacturing
    • On the Floor
