Stainless Steel Front Face Inductive Sensors
By Patrick Curran | August 18, 2009
Minneapolis, MN – TURCK announces its complete line of 2 and 3-wire DC ArmorGuard™+ stainless steel front face inductive sensors. The line includes 8, 12, 18 and 30 mm barrel diameters with 1.5 to 10 mm achievable sensing distances.
The sensors feature one-piece construction and IP 68 and IP 68K ratings, making them particularly suitable for food and beverage industry applications requiring frequent washdowns. Select sensors are available with TURCK’s proprietary WeldGuard™ protective sensing face material, which resists weld slag build-up and abrasion often found in robotic welding applications, including those in the automotive industry.
The sensors come equipped with an M12 quick disconnect connection or with potted-in 2 m cable for ease of installation on the plant floor.
TURCK
www.turck.us
Filed Under: Sensors (position + other), Test + measurement • test equipment
mti
MTI
moog
