Stainless steel inch thread leveling feet with turned base from JW Winco
By Mike Santora | April 5, 2018
JW Winco-Stainless-Steel-Leveling-FeetJW Winco, Inc., A Ganter Company, a supplier of standard industrial machine components, now offers Stainless Steel Leveling Feet, with inch size threaded stud and turned base. Bases are available with Mounting Bores (GN 23) and without Mounting Bores (GN 21).
The leveling feet, which are RoHS compliant, are delivered assembled and cannot be disassembled. The base is stainless steel, European Standard No. 1.4301 (AISI 304), while the threaded stud is stainless steel, European Standard No. 1.4305 (AISI 303) and the hex nut is stainless steel, European Standard No. 1.4305 (AISI 304, ISO 4032). The leveling feet also feature an inlaid non-skid pad.
JW Winco offers an extensive selection of inch and metric size adjustable levers, cabinet U-handles, plastic and steel hinges and locking mechanisms, revolving and retractable handles, hand wheels, hand cranks, tube connection and conveyor components, inch and metric construction tubing, shock absorption mounts, leveling mounts, hand knobs, spring, ball and indexing plungers, jig, fixture and fastening components, retaining magnet assemblies, toggle clamps, metric casters and wheels, universal joints, oil sight glasses, and metric tools for the industrial and commercial equipment industries.
JW Winco
www.jwwinco.com
Filed Under: ALL INDUSTRY NEWS • PROFILES • COMMENTARIES, Fastening + joining • locks • latches • pins
Tagged With: jwwinco
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
