Stainless Steel Indexing Plungers with Plate Mount from J.W. Winco
By Laura Carrabine | October 21, 2011
J.W. Winco, Inc. announced it now offers series GN 608.5 Stainless Steel Indexing Plungers with Plate Mount, non lock-out type, in metric sizes. The type of indexing plunger is used in applications that require surface mounting.
Types with tapped hole or with threaded stud are offered. This series has been expanded with additional plunger pin lengths to widen the application opportunities. Please note that for these longer pins lengths (14 and 18 mm), the pin does not fully retract. Plunger pin is made of stainless steel, chemically nickel-plated. Mounting plate is stainless steel. Knob is fabricated from matte black glass fiber reinforced nylon plastic, not removable. These plungers are RoHS compliant.
JW-Winco-Stainless-Steel-Indexing-Plungers-with-Plate-Mount
J.W. Winco
www.jwwinco.com
Filed Under: Fastening + joining • locks • latches • pins
C2 lever latch offers auto-relock functionality and modern appearance
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
