Stainless Steel Mini Ball Valves
By Patrick Curran | June 11, 2009
osco introduces a new HBV series of stainless steel Mini Ball Valves for compact paint delivery applications. The new mini ball valves are an economical alternative to standard ball valves and can lessen engineering problems for compact installations such as robot arms, enclosures and bulkhead plates. The new mini ball valves are 1/2 inch shorter than typical SSBV ball valves plus their new butterfly handle results in a smaller footprint. The handle also has a hole for easy tagging.
The new mini ball valves are an economical alternative to standard ball valves and can lessen engineering problems for compact installations such as robot arms, enclosures and bulkhead plates in paint delivery systems.
Like all Hosco paint system fittings and valves the new mini valves are silicone free, smooth bore and cavity free. The 7mm-full port ball provides the same performance as Hosco’s SSBV series while the Teflon encapsulated seals provide chemical, pressure and temperature stability. The all stainless steel construction is available in 303 or 316.
The threaded fittings are of Hosco’s new TruFit® Low-Shear design which eliminate paint agglomerating or dead zones in paint system assemblies. These fittings reduce system pressure loss and improve the ease and ergonomics of installation procedures because they require less torque during installation while furthering overall operational safety. These benefits are the result of incorporating a tapered opening at the end of the fittings, aligning with a compatible taper on the mating connection fitting.
The new mini ball valves are available in three different bodies; compression
(optional bulk head); tube stub and male threaded choices (metric & fractional inch, BSP/PF, NPS, BSPT/PT and NPT) with six different end connections; compression (optional bulkhead); tube stub, and male & female thread choices including reverse bulkhead.
Hosco
www.hosco.net
Filed Under: Factory automation, Mechanical, Valves
Solid-state relay characteristics and applications
