SRG stainless-steel pneumatic cylinders from Parker Hannifin Corp. are ideal for caustic, corrosive environments all the way up to laboratory facilities. The SRG series is available in five bore sizes ranging ¾ to 2 ½ in., with four possible mounting styles—nose, pivot, flange, and foot. They are rated for operating pressures to 250 psig (17 bar) and temperatures of –10° to 165°F.
In addition to a stainless-steel body, they feature 303 stainless-steel piston rods. Urethane rod wipers, lipseals and Buna-N as standard ensure long life. Fluorocarbon seals are available as an option.
Durable service is ensured with precision-machined aluminum pistons and piston rods, while piston rod connectors are threaded for leak-proof service. In addition, double-rolled unitized construction enhances the cylinder’s leak-proof design.
www.parker.com
Filed Under: Cables + cable management, Pneumatic equipment + components, Connectors (electrical) • crimp technologies
