    • Subscribe!
Stainless Steel Super Air Nozzle™ from EXAIR
By Patrick Curran | November 10, 2011
EXAIR’s new 1 NPT Stainless Steel Super Air Nozzle™ delivers 6.6 pounds of strong blowing force for blowoff, cooling and drying applications located in corrosive, high temperature, food and pharmaceutical environments. Because the force is more than 8 times that of ordinary air nozzles, it is ideal for blowing heavy materials and where the air nozzle can’t be mounted close to the target surface.
EXAIR-Stainless-Steel-Super-Air-Nozzle
The aerodynamic design of the 1 NPT Stainless Steel Super Air Nozzle directs compressed air to a single point of convergence, delivering a concentrated stream of high velocity airflow with hard-hitting force. Safe operation is assured since the airflow cannot be blocked (as required by OSHA standard 29 CFR 1910.242(b)). At 80 PSIG, the air consumption is 135 SCFM and the sound level is 99 dBA, meeting the OSHA standard for 2 hours of use per day without hearing protection.
The Type 316 stainless steel construction of this Super Air Nozzle has a 1-1/2″ (38mm) hex body for easy installation using a standard wrench or socket. Applications include ejection of heavy parts, drying, part and machinery cleaning, chip removal, liquid blowoff, and cooling hot parts. Price is $349.
EXAIR Corporation
www.exair.com/1114SS.htm
Filed Under: Pneumatic equipment + components
5 ways to improve packaging machinery with smart pneumatics
Clippard-Cordis-CFC-electronic-Flow-Controller
Cordis flow controller offers high resolution and repeatability in a closed-loop system
Upgrading equipment with solenoids
Clippard Eclipse proportional Valve
Proportional isolation valve offers ultra fine resolution and high repeatability
    • Subscribe!
