Stainless Steel Wing Nuts
By Design World Staff | May 27, 2008
NEW BERLIN, WI — J.W. Winco, Inc., a leading supplier of standard industrial machine components, announced it now offers Wing Nuts in blank, tapped, and tapped through hole versions.
Made of stainless steel in a hot stamped, matte shot-blasted finish, the Wing Nuts have a slight dimple on the ends to permit better grip and provide increased finger contact area. For certain minimum quantities, the blank version can be tapped or reamed in inch or metric sizes to meet customer requirements.
www.jwwinco.com
Filed Under: Fastening + joining • locks • latches • pins
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
