Regal Beloit Corporation, a manufacturer of electric motors, electrical motion controls, power generation, and power transmission components, announced that its Grove Gear Stainless Steel Worm Gear Reducer has achieved third party IP69K certification.
Ingress Protection (IP) Marking rates the degree of protection provided by mechanical casings and electrical enclosures against intrusion, dust, accidental contact, and water. It is published by the International Electrotechnical Commission (IEC). The IP69K rating is for high-pressure, high-temperature washdown applications. Enclosures conforming to it must not only be dust-tight but also able to withstand high pressure and steam cleaning.
The Grove Gear Stainless Steel Worm Gear Reducer now joins the Hub City Hera Stainless Steel Gear Drive, Sealmaster PN Gold Mounted Bearings, and the Leeson Extreme Duck Ultra Motor as third party IP69K-certified products from Regal. Together, these four products provide a complete washdown solution for food and beverage, pharmaceutical, and chemical processing applications.
“Traditionally, IP ratings have been used for electrical components, but the industry is starting to recognize the benefit of IP rating for power transmission components,” said David Silverman, product manager of worm gearing at Regal. “This allows our customers to have a better understanding of the product capabilities for specification purposes. We are pleased that the Grove Gear Stainless Steel Worm Gear Reducer now carries the formal IP69K certification.”
This Grove Gear Stainless Steel Worm Gear Reducer has a 316 stainless steel housing to withstand extreme environments. An O-ring on the face of the motor adapter, poppet-style vent, and v-rings on the output shaft seals provide a system that fights dust and moisture intrusion. A 303 stainless steel output shaft and stainless steel hardware are also included.
This reducer is also available with Leeson motors pre-assembled for the perfect performance-matched and IP69K-certified solution.
Regal Beloit
RegalBeloit.com
Filed Under: ALL INDUSTRY NEWS • PROFILES • COMMENTARIES
