STAUFF Mini Water Vac Cleans Oil Continuously
By Stacy Combest | August 12, 2013
The STAUFF Mini Water Vac purifies hydraulic system oil, eliminating water, gas and particulate matter. The purified oil satisfies the most stringent quality requirements.
The STAUFF Mini Water Vac dehydrates and cleans most types of oils such as lubricating, hydraulic, transformer, and switch oils while it neither removes nor alters oil additives.
The water removal process is based on pure vacuum evaporation inside a vacuum chamber at a maximum temperature of +65 °C / +149 °F.
Solid particle removal is achieved through a field-proven STAUFF Systems Micro Filter.
The oil temperature can be set using the integrated heater thermostat. The dehydration and filtering process is fully automatic and is controlled via the PLC.
Contaminated oil greatly increases maintenance costs and contributes to catastrophic machine breakdowns. The STAUFF Mini Water Vac offers protection against malfunctions, breakdowns and total system failures.
The STAUFF Mini Water Vac also protects the environment by reducing oil consumption and oil disposal.
STAUFF
www.us.stauff.com
Mobile Hydraulic Tips
Tagged With: stauff
