Steel and Stainless Steel Toggle Hook Latches
By Laura Carrabine | October 11, 2010
NEW BERLIN, WI — J.W. Winco, Inc. now offers series GN 833 and 833-NI Steel and Stainless Steel Toggle Hook Latches.
Steel_&_Stainless_Steel_Toggle_Hook_Latches
The metric sized latches are RoHS compliant. The GN 833 version is zinc-plated steel, yellow passivated, and the GN 833-NI version is stainless steel, European Standard No. 1.4301 (American Standard Series 304). They have a load capacity of 500 FH[N].
These toggle hook latches are used for the secure holding of flaps, container lids, etc. They lock securely over the center and are thus vibration proof. The components to be linked are held in position by the elasticity of the pulling latch.
J.W. Winco
www.jwwinco.com
Filed Under: Assembly, Fastening + joining • locks • latches • pins
Comments
  1. togelmania says
    May 11, 2017 at 8:13 am
    Great website you have here but I was curious
    if you knew of any message boards that cover the same topics discussed here?
    I’d really like to be a part of online community where I can get responses
    from other knowledgeable people that share the same interest.
    If you have any recommendations, please let me know. Cheers!
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
