Steel blades cut hydraulic hose
By Hilary Crisan | January 15, 2016
ModelBBCut-Off Blades, LLC provide machined tool steel cut-off blades, made for extra wearability and re-sharpening capabilities.
The blades, available in .095 and .125, are available in standard, bevel-edge, bevel-notched edge or scalloped edged. They can be used on most machines, and can be sized for AeroQuip, Dayco Gates, Imperial, Eastman, Parker, Stratoflex, Toledo and Weatherhead cut-off equipment.
Model BB
  • bevel blade
  • available in 7, 8, 10, 12 and 14 in.
  • range in price from $94 to $325ModelHP ModelSB
Model HP
  • bevel-notched blade
  • available in 7, 8 and 10 in.
  • range in price from $120 to $200
Model SB
  • scalloped blade
  • available in 7, 9, 10, 12 and 14 in.
  • range in price from $140 to $360
Cut-Off Blades
cut-offblades.com
The post Steel blades cut hydraulic hose appeared first on Hose Assembly Tips.
Filed Under: Hose Assembly Tips
Tagged With: cutoffblades
single-cover-small-232x300
Midland Metal launches updated 2017 catalog
nfpa
NFPA hosting Chicago Regional Meeting on December 7
RYCO Hydraulics debuts 24-7 program in Houston
NAHAD’s charitable water cause surpasses $10,000 mark
