Steel Leveling Sets Now Available from J.W. Winco
By Patrick Curran | August 28, 2009
NEW BERLIN, WI
— J.W. Winco, Inc. announced it now offers series GN 350.2 Steel Leveling Sets with Spherical Washers.
These leveling sets are used for leveling, adjusting, and linking operations. Offered in metric sizes, the sets are RoHS compliant. They are made of zinc-plated, blue passivated steel.
The spherical washer allows precise installation of two non-parallel planes at a required gradient up to ~4°. Leveling sets consist of a threaded upper sleeve and a tapped lower sleeve. The fine thread allows precise, stepless setting and locking using a DIN 1810A hook spanner wrench. An anti-rotation disk serves also as a height limiter for the maximum height. Normally this screw is permanently and securely locked by the static load created when the mounting screw is tightened. If this is not sufficient, the use of a locknut is recommended. A version including the locknut is offered.
J.W. Winco
www.jwwinco.com
Filed Under: Assembly, Fastening + joining • locks • latches • pins, Washers • spacers
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
