Steel Mini Indexing Plungers from J.W. Winco
By Patrick Curran | November 6, 2009
NEW BERLIN, WI — J.W. Winco, Inc. announces it now offers series GN 822.1 Steel Mini Indexing Plungers.
These indexing plungers feature six lock-in and lock-out positions.  They are made of zinc-plated, blue passivated steel, with stainless steel plunger and spring, and a knob of matte black glass fiber reinforced nylon plastic, not removable. Offered in metric sizes, they are RoHS compliant.
These indexing plungers feature small, compact dimensions, and are designed for installation in thin walled sheet metal applications.  They offer a lockout position for applications that require the plunger pin to be retracted for an extended period of time.  Plungers are inserted into position by holding them by the knurled knob. The wrench flats on the lock nut are exposed when the pin is retracted, so that the plunger can be easily tightened by means of an open end wrench.
J.W. Winco
www.jwwinco.com
Filed Under: Assembly, Fastening + joining • locks • latches • pins
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
