Steel telescopic slides available from JW Winco
By Mike Santora | June 20, 2018
JWWinco-Steel-Telescopic-SlidesJW Winco now offers an assortment of GN 1400 series Steel Telescopic Slides with full, partial, and double-sided full extensions.
With a range of extension types and additional functions and dimensions, these RoHS compliant slides can handle loads of between and 50 and 700 pounds (220 and 3100 N) of force per pair. The 13 new variations, which feature telescopic rails made of rolled sheet metal, are suitable for use in a number of different applications.
Depending on the length of the extension, between 250 (9.84-in.) and 1,500 mm (59.06-in.), the steel telescopic slides are made up of two, three, or four interconnected slides. Winco’s product range includes a wide scope of solutions in terms of features, including latches and dampening systems.
The slide profile is steel, zinc plated, with a blue passivated finish. The bearings are steel and hardened, while the ball cage outer slide is either steel with a zinc plated finish or plastic, with a steel, zinc plated inner slide. The rubber stops on select versions are plastic/elastomer, while the self-retracting mechanism is stainless steel and plastic. The telescopic slides function in operating temperatures or -4 to 212 °F (-20 to 100 °C).
JW Winco offers a selection of inch and metric size adjustable levers, cabinet U-handles, plastic and steel hinges and locking mechanisms, revolving and retractable handles, hand wheels, hand cranks, tube connection and conveyor components, inch and metric construction tubing, shock absorption mounts, leveling mounts, hand knobs, spring, ball and indexing plungers, jig, fixture and fastening components, retaining magnet assemblies, toggle clamps, metric casters and wheels, universal joints, oil sight glasses, and metric tools for the industrial and commercial equipment industries.
JW Winco
www.jwwinco.com
Filed Under: ALL INDUSTRY NEWS • PROFILES • COMMENTARIES, Fastening + joining • locks • latches • pins
Tagged With: jwwinco
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
