Burlington, MA – Steinmeyer, Inc. announced a new, product, The MP63 3 axis micro manipulator module. It‚’s a fully enclosed 3 axis positioner with 25 mm stroke in each direction. Included inside the compact precision assembly are dc gear motors, rotary encoders, lead screws, and non-contact limit switches. Accuracy in each direction is 5 microns with ‚± 1 micron repeatability. Standard straightness and flatness is ‚± 3 microns (1 micron is available as an option). The entire assembly weighs about 2 kg and all components are inside. Cable connectors are located on one end for convenience and simplicity. And, as an option, the assembly can be made clean room compatible.
Steinmeyer, Inc
www.steinmeyer.com
Filed Under: Factory automation, Encoders (rotary) + resolvers, MECHANICAL POWER TRANSMISSION
