Designer’s Corner is an online step motor selection tool that allows designers to select a motor that will work within their application’s specifications. With 3 easy steps, it is user-friendly. Designers can enter data based on one of the following applications:
Belt-Pulley
Direct Driver
Lead Screw
Rack & Pinion
Designer’s Corner is available free of charge at www.linengineering.com. There is no software to download; only a simple registration process is required to use this tool. Below is a description of the step motor selection process with Designer’s Corner:
After your motor is selected, you can request a quote from a Customer Service Professional. For a limited time only, the first motor you select using Designer’s Corner can be requested at no charge.
Lin Engineering
Filed Under: MECHANICAL POWER TRANSMISSION, Motion control • motor controls, Motors • servo
