Stewart Connector introduces a complete line of IP20 rated modular plugs complimenting the existing standard RJ45 modular plugs.
Stewart Connector’s IP20 rated RJ45 modular plug line has been developed to bring reliable data connections to industrial environments at Gigabit Ethernet (1000Base-T) through 10 Gigabit
Ehernet (10GBase-T) transfer rates while supporting Power over Ethernet (PoE) applications. The IP20 modular plugs are designed to be terminated to shielded or unshielded cable with solid or stranded conductors. Connector options are available to accommodate a wide range of overall cable (.230”-.330”) and conductor diameters (.033”-.062”) found on harsh environment and industrial cables. The double clamping strain relief delivers the most robust connector to cable connection available to support the conditions found in industrial environments.
Applications for Stewart’s IP20 modular plug line include data, telecommunications and industrial equipment connections. The low-profile design of the modular plugs is well suited for high-density switches and routers as well as CAT5E through CAT6A premise networks. The IP20 modular plugs are installable in both field or
factory environments.
Stewart Connector
belfuse.com/stewart-connector
