Stratasys announces the availability of the Origin Two DLP printer in tandem with its post-processing system, the Origin Cure. This solution addresses the growing demand among manufacturers for injection-molding quality for short production runs, delivering a level of accuracy, repeatability, and surface finish previously unattainable with additive manufacturing.
Traditional high-volume manufacturing is under pressure due to many challenges, such as supply chain disruptions, material shortages, and changing consumer preferences. There is a growing demand for low-volume production solutions to offset the costs of mass production. Additive manufacturing with the new Origin Two is designed to eliminate the high setup and tooling costs typical for low to medium-volume production while meeting customers’ most stringent precision requirements.
The new Origin Two, with Origin Cure, aims to address the critical pain points by enabling manufacturers to:
- Ensure that end parts meet required properties by maintaining stringent quality controls
- Bring production in-house, thereby reducing reliance on third parties
- Improve inventory management and lower warehousing costs with on-demand delivery of spare parts
- Consolidate part manufacturing into a single process with better consistency
“Additive manufacturing has grown to be a critical component of production at any scale on the manufacturing floor,” said Rani Hagag, Chief Healthcare and Consumer Business Officer, Stratasys. “With the new Origin solution, manufacturers in need of low volume, high precision parts now have an alternative to mass production that can meet their most stringent requirements, something which was not possible with additive before.”
The new solution is designed to achieve consistently higher accuracy of +/- 50 µm, critical for connectors, aerospace, and automotive industries. For applications such as seals and gaskets, housings, and window parts, it provides additional essential features, including:
- Achieving repeatability of more than 93% within +/- 50 µm across Origin Two printers and surface finish smoothness of up to RA 3 µm while maintaining high-print speeds of up to 20 mm/hour.
- The Origin Two’s heated chamber enables reliable printing of materials with a Heat Deflection Temperature (HDT) of up to 300°C, making it suitable for a wide range of high-performance applications.
- The Origin Two system runs on a 385-nanometer wavelength and supports a range of high-performance materials, from high-temperature resins to high-viscosity formulations.
“Additive manufacturing is becoming increasingly valuable for low production volumes in the manufacturing sector,” said Ryan Martin, senior research director at ABI Research. “Manufacturers are using 3D printing for low-volume and custom parts, which helps reduce lead times and waste. This allows for greater flexibility and cost efficiency, supporting both prototyping and on-demand production. As a result, additive manufacturing is proving to be a practical solution for companies looking to adapt quickly to market needs and reduce inventory costs.”
Where to see the new Origin Two and Origin Cure:
The Origin Two and Origin Cure will be showcased at the Stratasys booth (West Building Foyer, booth #433007) at the upcoming International Manufacturing Technology Show (IMTS) in Chicago, September 9-14.
The new hardware will be commercially available starting September 5th; for more information or to schedule a demo, please visit the Stratasys website.
You may also like:
