Watch a how-to video here about tool usage methods for properly removing stripped screws and screws with damaged recesses.
NBK, a specialist manufacturer of mechanical components, offers Impact Screwdrivers and Stripped Screw Removal Bits. These tools are ideal for removing stripped screws or those with damaged recesses, which are unable to loosen with conventional tools.
Damage may occur for several reasons, such as when recesses are crushed because of rust or corrosion from long-term exposure to outdoor environments or simply due to incorrect tool use or faulty attempts to forcibly remove stuck screws.
Impact Screwdrivers and Removal Bits can be used together to create grooves in damaged recesses, which can then be turned to safely and effectively remove the screw.
These tools can also be used to remove flat-head screws that fail to grip with a wrench or screws in counterbored holes.
NBK
nbk1560.com
