Subsea position sensing solutions
By Heather Hall | May 11, 2022
Alliance Sensors Groups announces its SSx-7 series of LVIT subsea position sensors. Available in full scale ranges from as short as 1 in. (25 mm) up to 36 in. (900 mm), these devices are constructed of AISI 316 stainless steel to operate at depths of 12,000 ft.
The SSx-7 body style easily fits into an SAE O-ring port in the end of a hydraulic cylinder and is terminated with the popular micro-circular subsea connector. Offered with common analog voltage or current loop outputs, standard SSx-7 series position sensors are good solutions for many subsea applications like:
  • Choke Actuators in a PBOF Environment
  • BOP Sealing or Shearing Ram Positions
  • Annular BOP Seal Compression Piston
  • ROV Electric and Hydraulic Actuators
  • Hydraulic Cylinder Position Sensing
Nevertheless, because some subsea position measurements may require a customized sensor to meet application-specific requirements. ASG offers short run sensor customization typically involving one or more of the following attributes:
  • Materials and seals for high pressures and/or PBOF operations
  • Compatibility with non-flammable EHC fluids like phosphate esters
  • Popular standard or special high pressure subsea connectors
  • Alternate analog I/Os or customer-specific digital outputs over an RS-485 bus
  • Simplified designs for higher reliability
Filed Under: SENSORS
Tagged With: alliancesensors, alliancesensorsgroup, Alliance Sensors Group
