Sunnyvale, CA – With a vivid screen and competitive pricing, 5.7” HG2G Operator Interfaces offer more functionality for less money. A new, super-bright LCD screen provides crisp images and superior visibility making the analog touchscreen easy-to-read even in intense light or at an angle. Behind the screen, the panel depth is only 36mm, making HG2G the best choice for narrow or limited spaces.
The HG2G 5.7” LCD touchscreen is available as a monochrome (500cd/m2) or 256-color (350cd/m2) display. An optional built-in Ethernet port (10/100 BaseT) allows remote communications with PLCs by using a supported Network Driver in 1:1 or 1:N Communications. Some of the supported drivers include IDEC (using the Web Server module), Allen Bradley Ethernet/IP and Modbus TCP/IP as well as others. The convenience of uploading, downloading and monitoring operator interface projects and data over the Ethernet means you save time and money by working remotely.
HG2G is RS232/RS485/RS422 compatible and supports IDEC PLCs, as well as all major PLC manufacturers. In addition, HG2G supports a wide range of other communication capabilities including 1:N PLC, O/I Link (HG2G Series only), User and Sub Host communication.
All HG2G models are CE-marked, c-UL-us listed, Nema 13 rated and have IP65 protection.
IDEC Corporation
www.idec.com/usa
Filed Under: Displays • HMIs • operator interfaces • monitors, ELECTRONICS • ELECTRICAL
