All Sensors Corporation Has announced the introduction of a Surface Mount Basic Pressure Sensor. This announcement comes as industry demand for surface mounted pressure sensors is increasing. In addition to standard pressure ranges, an unprecedented 10-INCH H2O pressure range is also available with virtually zero position sensitivity. The Surface Mount Basic Pressure Sensor is RoHS compliant.
The Surface Mount Basic Pressure Sensor is available as a gage or absolute pressure sensor. Packages can be configured with a ported lid or a non-ported lid. The footprint of the device measures 0.3” x 0.3”. The Surface Mount Basic Pressure Sensor is packaged as an 8-pad leadless chip carrier.
Electrical Features
The Surface Mount Basic Pressure Sensor is available as a gage device with pressure ranges of 10 INCH H2O, 5 PSI, 15 PSI, 30 PSI, and 100 PSI, as well as an absolute pressure device with a range of 15 PSI. The output is ratiometric to the supply voltage and proportional to the applied pressure.
Price
Contact factory for price. Surface mount sensors are available from stock, however, consult factory for real-time availability.
16035 Vineyard Blvd. Morgan Hill, CA 95037
TEL: 408 225 4314 FAX: 408 225 2079
www.allsensors.com
Contact:
Dan DeFalco
408 225 4314 tel
408 225 2079 fax
[email protected]
Filed Under: Data acquisition + DAQ modules, Sensors (pressure), SENSORS
