Surface Temperature Connector/Sensor from Omega
By Dave Miyares | July 14, 2011
Omega’s new easy to use STC-100 series of surface temperature connector/sensor plugs directly into most handheld thermometers. It is available in K or E thermocouple types. The small, compact connector body has a fast 250 msec response time and features an integral thermocouple sensor specifically designed for low temperature surface measurements and can be easily removed for cleaning or replacement if damaged. It can be plugged to any Type K or E Handheld Meter with Flat Blade contacts and provides fast and accurate readings. The 1″ diameter body design allows easy access to the heated. The STC-100 is ideal for anywhere fast, accurate readings are needed.
OMEGA-Surface-Temperature-Connector-Sensor-STC-100
Omega Engineering
www.omega.com
Filed Under: Connectors (electrical) • crimp technologies, Sensors (position + other), Sensors (temperature), Test + measurement • test equipment
molex-versablade-300x300
Heilind Electronics now offering Molex VersaBlade Wire-to-Wire Connector System
bel-stewart-m12xcode-connector
Stewart Connector M12 X-Code PCB mount connectors
Heilind-electronics-product-image
Heilind Electronics now offering Molex PowerPlane BusBar Power Connectors
Harting Technology Group heads for a climate-neutral future with record investment
