SV7 Servo Drive with Ethernet/IP Connectivity from Applied Motion
By Miles Budimir | November 11, 2011
Applied Motion Products announces the availability of an EtherNet/IP connectivity option for their SV7 servo drive. The SV7 is a compact, 24 to 80 VDC sine servo drive and is available with specially matched 50 to 300 watt V series NEMA mount servo motors as well as M series metric mount, IP rated servo motors.
Applied-Motion-SV7-servo-drive
The SV7-IP includes eight digital inputs, four digital outputs and two +/-10V analog inputs. The EtherNet/IP command set provides access to all drive control modes, I/O and parameters using EtherNet/IP class 3 explicit messaging. Q language programs stored in the drive can also be triggered over EtherNet/IP. This servo drive is the perfect solution for applications requiring connectivity to Rockwell/Allen Bradley PLCs.
Matching 24 VDC and 48 VDC power supplies ship from stock.
SV7 models are also available supporting SCL and Q languages over Ethernet UDP and TCP, RS-232 and RS-485 communication ports. CANopen and Si programming units are also in stock. All models and matching motors can be ordered online at www.applied-motion.com
Filed Under: Factory automation, CONNECTIVITY • fieldbuses • networks • gateways, Drives (servo) + amplifiers, Motion control • motor controls, Motors • servo
Miles Budimir
