Synchronous Drives Feature Dual Sprocket Design
By Design World Staff | April 14, 2009
TB Wood‚’s brand Synchronous Plus‚â„¢ drives have a dual sprocket design with both metric and standard-tapped holes coupled with a Synchronous Plus belt. The design allows for the use of smaller, lighter weight sprockets.
The belts feature helically wound, strong fiberglass cords chemically treated for length stability, flexibility, and high tensile strength for shock loads.  Teeth are molded integrally with a backing that protects the tensile members. Teeth and backing components are manufactured from premium quality, synthetic rubber. Precise tooth formation and accurate spacing permit quiet, smooth, uniform transmission of power with resistance to tooth jump and shear. Load capacities are available for a range of torque loads.
Altra Industrial Motion
www.AltraMotion.com
Filed Under: Belts + chains, Motion control • motor controls
49503-ACS Motion-CMxa
SDP-SI-040
PACMotion-servos
