Klϋber Lubrication, a worldwide manufacturer of specialty lubricants, offers Klübersynth UH1 14-151, a synthetic lubricating grease for the food and pharmaceutical processing industry, readily available from our US facility in Londonderry, NH.
Klübersynth UH1 14-151 is designed with anti-wear properties, water resistance and corrosion protection, which reduce the risk of premature bearing failure, as well as a high ageing and oxidation stability.
The lubricant was developed for incidental contact with products and packaging materials in the food-processing, cosmetics, pharmaceutical and animal feed industries. Klübersynth UH1 14-151 is NSF H1 registered and, therefore, complies with FDA 21 CFR § 178.3570.
The Klübersynth UH1 14-151 lubricates rolling and sliding bearings, lifting cylinders, joints, guide bars and cams.
Kluber Lubrication
www.klueber.com
Filed Under: Uncategorized
