T-Handle Rapid Release Pins from JW Winco
By Mike Santora | March 14, 2019
JW-Winco-WN-100-T-Handle-Rapid-Release-PinsJW Winco, Inc., A Ganter Company, a supplier of standard industrial machine components, now has available WN 100.1 T-Handle Inch size Rapid Release Pins with Stainless Steel Shank.The WN 100.1 T-handle rapid release pins have a wide range of applications in fastening, locating, and alignment applications.
“The pin will not release until the button on the handle is depressed,” said John Winkler, CEO, Office of the President at JW Winco. “Once the button is depressed, the balls retract into the shank allowing the pin to be inserted into or removed from its position.”
The product is appropriate for applications within the packaging, medical, woodworking, exercise, work-holding, and material handling industries.
The shaft, inner spindle, split ring, spring, and balls are all stainless steel, while the handle is a die cast aluminum with a black anodized finish. The rapid release pins are available upon request in other diameters, materials, lengths, handle configurations, and with other modifications.
JW Winco also offers a  range of cables for loss protection to be used with the WN 100.1 T-Handle rapid release pins when the application requires significant handling and the pin could be misplaced. For ball chains, see our GN 111/GN 111.5, for retaining cables, see our GN 111.2, and for spiral retaining cables, see our GN 111.4.
For Metric T-handle pins, please see JW Winco’s GN 113.7 T-Handle Ball Lock Pins.
JW Winco is a manufacturer/distributor of inch and metric standard parts. JW Winco offers an extensive selection of plastic, steel and stainless steel adjustable levers, cabinet U-handles, hinges and locking mechanisms, revolving and retractable handles, hand wheels, hand cranks, tube connection and conveyor components, construction tubing, shock absorption mounts, leveling mounts, hand knobs, spring, ball and indexing plungers, jig, fixture and fastening components, retaining magnet assemblies, toggle clamps, casters and wheels, universal joints, oil sight glasses, and metric tools for the industrial and commercial equipment industries.
JW Winco
www.jwwinco.com
Filed Under: TECHNOLOGIES + PRODUCTS, Fastening + joining • locks • latches • pins
Tagged With: jwwinco
55416_commModule_APL_300dpi_cmyk
Softing introduces a hardware module for implementing Ethernet-APL field devices.
IO-Link Smart Field I/O System from AutomationDirect
50 years of bit parallel encoders from POSITAL
EXAIR 3D model and CAD Library has more than 70 extensions
